Use the following procedure to create and configure an IKEv2 profile.
  1. In the navigation pane, expand Configuration > Security > Control Path.
  2. Select IKE.
  3. Select the V2 Profile tab.
  4. Select Insert.
  5. In Name, type a profile name.
  6. Complete the remaining optional configuration to customize the policy.
  7. Select Insert.
V2 Profile Field Descriptions
Use the data in the following table to use the V2 Profile tab.
Name
Description
Name
Specifies the IKE v2 profile name.
HashAlgorithm
Specifies the type of hash algorithm that can be used during IKE version 2 SA version 2 negotiation.
The default value is sha256.
EncryptionAlgorithm
Specifies the encryption algorithms that can be used during IKE version 2 SA version 2 negotiation.
The default value is aesCbc.
EncryptKeyLen
Specifies the type of encryption algorithm. The default value is keylen–256.
DHGroup
Specifies the Diffie-Hellman (DH) group. DH groups categorize the key used in the key exchange process, by its strength. The key from a higher group number is more secure. The default value is modp2048.
ExchangeMode
Specifies the IKE v2 profile negotiation mode.
The default value is main.
LifetimeSeconds
Specifies the lifetime value in seconds. The lifetime ensures that the peers renegotiate the SAs just before the expiry of the lifetime value, to ensure that Security Associations are not compromised. The default value is 86400 seconds.
IntegrityAlgorithm
Specifies the type of integrity algorithm. The default value is sha256.
